This command has been replaced with the following command: disable l2vpn [vpls [vpls_name | all] | vpws [vpws_name | all]].
This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.
Disables the VPLS instance specified by vpls_name.
vpls_name | Identifies the VPLS within the switch (character string) |
all | Specifies all VPLS. |
All newly created VPLS instances are enabled.
This command disables the VPLS instance specified by vpls_name. When a VPLS instance is disabled, all sessions to its configured peers are terminated. Any locally attached service VLAN/VMAN is immediately isolated from other devices residing in the VPN. If this is an H-VPLS core node, then all spoke nodes connected to this peer are isolated unless redundant core access is configured.
The following example disables the VPLS named "myvpls":
disable vpls myvpls
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
